Old 01-09-2012, 01:14 PM
Default exhaust stack
Here is my homemade stack on the 128 I felt the need as I was getting to many fumes on long drives. My header pipe doesn't want to turn and is pitted rust , so for now I am gust going to leave it alone . I took a auto parts 65 degree bend 2 1/8 exhaust pipe and cut a 1 1/8 inch hole in one end to slip over the header and tack the two together , a freeze plug fits up the pipe and tack weld it to close up the open end . I bolt it to the head plate the same as the original muffler using a blind nut welded atop 2 nuts . Now just have to make the bend then go up which I welded a 90 yes a curved bend would be better think of 2- 22.5 degrees bends to get better flow. I just siliconed and pop riveted a couple of conections so I can addapt a mosquito fogger by injecting insectiside into the end , after taking out the 90 bend . I have noseeam mosquitos here now man I hate those things.
The 2nd pic shows the 1inch pipe inserted on the stack to create a muffler of sorts and it works well as now I hear the valves are a little loose
128
Old 01-09-2012, 01:28 PM
Nice work on the stack green 4 acres
That ought to keep the fumes out of your face.
Old 01-09-2012, 01:38 PM
Well said, Diz!
Old 01-09-2012, 01:39 PM
Cool exhaust, but, my trees would make a quick removal of that pretty stack.
(The trees would remove the cab too)
I had thought about a down exhaust, but, since I have a QL front exit muffler for the past couple months, I am convinced I will stay with the front exit, but it is not as good looking as a stack!!
Good looking work!!
Old 01-10-2012, 08:39 AM
mickb72 mickb72 is offline
Default stack
Hey green 4 acres are you saying you are going to inject pestiside into the exaust? Great idea? I'll be following this as we have been invaded with those noseeums here in ohio too. I thought they were a florida thing. Mike
Old 01-10-2012, 10:59 AM
Yes just a spritts of it to turn to fog
I have seen regular mosquitos swarmming in the sunshine a week ago here. I have a tank sprayer I use but really need to fog them. I may have brought them here from my trips to Key Largo/ West .
Old 07-10-2012, 05:02 AM
NW Hick's Avatar
NW Hick NW Hick is offline
Default Nice work!
That's a nice pipe, tho I'd be wondering about all that weight shaking out at the end of the torque wrench/exhaust pipe....?
I went for a downswept pipe exiting below the right footrest. I got real tired of breathing exhaust, especially on a big mow job. I tried several versions before I got to this one...I did try a short stack with a top hat, but it still threw exhaust in my face and the noise of the top hat drove me crazy. Also, I take mine out in the woods pretty often, and a tall stack would last about five minutes.
My friend gave me a set of Harly pipes, which I took as a challenge to make them work. This seems to do the job....the bends of the pipe enabled me to have clearance to pull the side cover but stay within the wheel base while pointing the exit the way I wanted. It also made it quieter! I did add a piece of angle iron across the frame extending out far enough to clamp the pipe to, which made it sturdier. There were a pair of friendly factory bolts already there, so I just grabbed on to them.
Steve
Cub 1641 - Accepted to settle a $400 debt
I got all of the original paperwork with my Cub! The buyer traded in something in for a $4999 credit, and used it to buy the 1641, a roller, wheel weights, box blade, mower deck & bagger, Ripper, Seeder, two sets of tires, and a trailer.
I added DOT headlights, tailights & flashers, a beacon, 3000 lbs winch, bumper & brushguard, 18 inch front tires, dump box, HD Exhaust, & scabbard.
Old 03-15-2013, 08:46 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
Why so tall?
Bi-Polar Plowboy Plowboy X Press
Old 03-15-2013, 09:59 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
that sure will keep the exhaust out of your face. more like an exhaust chimney.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 03-15-2013, 10:12 PM
Donovan M.'s Avatar
My 1250 has a stack and I have a turn out on it so its not in your face.
Donovan:
62' Original-fenders
