Just purchased a 2182 and mowed with it last weekend. It did a good job and worked like it should around the house. But, after I parked it, an hour or so later, I started mowing the pasture fence lines, and the power steering was hardly working. Now, it doesn't work really at all. The fluid check under the seat shows full. It's pretty clear fluid, but is just below full. The tractor was sitting for quite awhile, one owner though excluding dealer. Any suggestions?
Thanks, Bob |
I would start with changing the fluid and filter, when the filter starts to plug the trans will still operate ok but things like hydraulic lift and power steering stop working.
What he said.
Ok thanks, I will try that.
Also, any reason why when I post I have a hard time finding my post, if at all? I saw even this post was "moved" with no posting detail in terms of time and date. Bob |
What would be the best fluid and filter to get? Would May nards have the good oil and filter or F&F? Nearest Cub Cadet dealer is about an hour away.
Bob |
Is there a Case International big tractor dealership close by? Get the Hytran oil there. I stick to Cub filters.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
2: Here is a list of acceptable hydro filters. I'm guessing you have a NAPA or O’Reilly Auto Parts Cub Cadet 923-3014 NAPA 1410 Wix 51410 Fleetgard HF6096 Baldwin BT8486
Ok, thanks.
Is there a chance there could be air in the system? Is there a bleed valve on the tranny I can use? |
No and no. Change the fluid and filter.
