My 102 project
Well. This has a long way to go. I picked this 102 up cheap and it’s in pieces, already blasted and primed. So here’s the beginning. The tunnel cover needed attention, a previous owner cut the hole out for some reason. So I replaced it. This is not completed yet. I need to do some sanding and prepping before it turns yellow. Tomorrow is supposed to be in the 60’s here so maybe I will get it painted...
5B160B55-DA8B-4789-99D3-4DDE54854FFB.jpg 03688811-CFEA-4AAE-BECB-479EC5476C81.jpg 6C2DABAF-44E0-4BFA-AE6A-C03B0E2B1D1A.jpg
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
Looking good Steve. I wish people would realize they can either access the stuff they need to underneath or flip the darn thing on its side, hang it by the front axle, something other than making windows in the frame.
I’m two for two on acquiring narrow frames with frame windows.
Here’s the rest of the 102, and the 100 in the background.
89B1602D-0D78-40E6-A6CF-76BD6D2531E5.jpg 190FA41A-782A-48D9-B679-582491A0959F.jpg 3CAE98D6-1592-4875-B3FB-C79934F16858.jpg
Nice patch job! Good work and it's almost done :-)
Thanks. I’m not very good at welding but that piece I cut from another tunnel and whittled it down to fit perfectly and I stick welded it in and knocked the slag off which revealed a nearly perfect bead that ground down smooth. I’ve never had anything come out that good.
Looks like a good project, keep us posted on your progress.
Patch looks good! You'd think by now, someone would have made a bolt in window to fix those and still be able to access from the top. 2 of the 3 NF here have been torched.
Nice job repairing the "window". Keep us updated on your progress.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
I thought about doing that, but decided it would probably be better to just do it so it looks original.
