Old 04-18-2018, 10:39 PM
Default Yep, it happened.
I was using the FEL on the 1772 a little hard the last few days and I cracked the frame where the power steering ram mounts to the frame. Never mind the half-a$$ed spacer I had to use to clear the mount. I was gonna change that someday when I had my shop but I ain't there yet.
IIRC this isn't an easy fix. Has anyone had any luck repairing them?
Pic needs turned 90* clockwise.
Old 04-18-2018, 10:52 PM
Dirty Steve's Avatar
Ouch! That sucks big time. I defer to others on the fix.
Old 04-18-2018, 10:53 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Repairing them" meaning a frame crack??
1- 1200 in pieces
1- 1864 in pieces
Old 04-18-2018, 11:07 PM
Take the mount off, v grind the crack and weld it. If you do it well, only need to weld the one side. I suggest adding a plate to the inside of the frame for added support. Or at least a flat bar between those to bolts where it cracked. Don't need to weld it in. Just use the bolts and sandwich the frame.
A spacer plate instead of those washers might help too.
This is an area of frame breakage I posted about a few months back. (And got called crazy and paranoid.) I've seen like 3 or 4, 982's broke there. (No power steering.) I think all those holes together make a weak spot on the frame. I've only seen the 9'S break there. This is the first tractor break there that had ps that I've seen/head of.
Yes, I have read several posts on different things people have tried with no luck. What stinks is this 1772 is in awesome shape with all original paint.
Old 04-18-2018, 11:11 PM
Thanks Jon. I need a good kick in the arse. I was flexing the frame too much lifting one rear wheel off of the ground trying to clean up some stuff on the burn pile.
Old 04-18-2018, 11:14 PM
Well Todd time to test out your welding skills and the Esab. I will add to what has been stated that you should drill a small hole at each end of the crack as well before welding.
Do your loader mounts stretch back to the rear axle?
Old 04-18-2018, 11:16 PM
Mike, I think there is about a 1/2" hole at both ends of the crack.
I started to state that too..... then thought about it a little more, lol.
Old 04-18-2018, 11:20 PM
I’d like to see the crack without the mount on there, looks like it’s above the big holes?.
