1572 driveline
Ok Fellas
What am I gonna get myself into here? The PO of my 1572 replace the rag joints but failed to put lock nuts on the bolts and while plowing the nuts backed out causing the rag joints to tare. Picked up all new rag joints today and hardware to fix. I'm wondering what is the best way to get the driveshaft out and what do I have to look forward to? |
It isn't a lot of fun. I would remove the battery and battery box, then start by removing the spirol pin that holds the forwardmost driveshaft-mounted rag joint coupler and unbolting the rag joint. Slide those parts back as far as you can, and then remove the bolts that hold on the engine-side driveshaft coupler (3 metric bolts, BTW) and then you should be able to move the whole thing to one side or up enough to slide off the pieces. Then you can unbolt the driveshaft from the rear coupler. Be sure to replace the spherical ball bushing in each coupler if they are at all sloppy, and make sure the rear coupler isn't wobbling around on the trans input shaft. Be sure to use locknuts on the rag joint bolts when you put it all back together.
thanks matt...i already got all the bolts and lock nuts from the ih dealer and the bushing...if the coupler is sloppy on the input shaft on the hydro am i pretty well s.o.l.? can that coupler be replace or do i need to do the shaft also?
The shaft is hardened and the coupler is pretty soft (in comparison) cast iron. You can still get them new last as of this summer...I had to buy one for my 1872. It was about $100, unfortunately.
