Old 01-18-2015, 01:53 AM
blee128 blee128 is offline
Default K321 Governor
Getting everything ready for pulling season I was running my motor the other day and when in gear the motor is either at idle or wide open I was told it was the governor needed adjusting but after trying to adjust it today the shaft free spins it doesn't stop so I'm assuming the gov. is broke is there a way to bypass it or if anybody has any ideas it would be greatly appreciated don't really have time to tear the motor down at this point
Old 01-18-2015, 04:12 AM
c69ss396 c69ss396 is offline
The tab has broke off the shaft, All you can do is pull the engine and replace the shaft.
Old 01-18-2015, 07:45 AM
Part # KH-A-235256-S $28.37
You may also want to replace the bushing it turns in at the same time to lessen the oil leakage around the shaft.
Just did this on my 1450.
or....you may be able to carefully weld the tab back on the shaft and save the original one, just make sure you orient the tab back on the shaft the correct way.
At any rate, this will require a major engine tear down.
Good time to take care of house cleaning in there while you are at it and check clearances. I was able add a .005" shim and bring my cam end clearance back up to spec. Sure hoping this will quiet the ol' AQS down a little!!
Good luck!!
Old 01-18-2015, 11:21 AM
And that tab is probably floating around in there some where.
Sooner or later its going to get flipped into the right spot and cause more problems.
Old 01-18-2015, 01:13 PM
A governors job is to control engine speed. Can you bypass it? Yep, it already is. That's how it's going to work with it bypassed. No engine control. Only solution is disassembly and repair. Sorry that's not what you wanted to hear. You might not have to take the engine apart as it may just be the tab on the cross shaft which can be removed without disassembly, but you still need to pull the pan and find the tab. Good luck.
Old 01-18-2015, 03:02 PM
I was hoping for a simple solution to my problem also, but after getting the engine out and on the stand, with the pan removed, you can barely see the tab or the shaft. I could see no way of removing and reinstalling it w/o pulling the crank etc.
The governor gear and cross shaft are the 2nd step in re-assembly and nearly the very last to come out in a tear down.
Old 01-18-2015, 03:09 PM
Guys I am sorry. I don't have any idea where my head is today. Yes, that is correct finsruskw. You have to disassemble to get the cross shaft in/out.
Lost my credibility today.
I was thinking about the gear. It can be removed and installed without disassembly. It has been discussed on here before. dvogtvpe has done it. I've never tried. Doubt the cross shaft would come out, but it may. You can pull the nut/bushing and have a look-see though. If the tab is gone, the cross shaft will come out, but it will be tough to get in with the cam in.
Old 01-18-2015, 03:50 PM
you had credibility?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-18-2015, 03:51 PM
Ok guys. I did it. I just went out, grabbed a motor I had sitting. You CAN get the cross shaft out without disassembling the motor. You just need a magnet and a screwdriver. Turns out I didn't give bad info.
It actually only took a couple minutes. It was pretty easy.
Old 01-18-2015, 04:15 PM
If I did have any..... Maybe I just earned it back?
