PTO runs rough
My tractor seems to run fine, but when I turn on the PTO to engage the blades, things start to shake a bit more than normal. I did just sharpen my blades but not sure if this is a PTO problem, mowing deck problem, engine problem? Any advice on where to check first?
I would assume, since you sharpened your blades, that you didn't balance them. You took more material off one side of the blades than the other, causing them to be unbalanced. This will cause the mower deck to shake more than normal. You can run them like this, it shouldn't hurt anything, but if you don't like the vibration you'll want to remove them and balance them properly. They sell little plastic blade balancers that should make it easy enough, I happen to have one myself.
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
AS A TEST.....
Unplug the PTO and see if the problem persists.
Ah Ok makes sense. I guess I will try both. I will unhook the belt from PTO and engage and see how that feels and then try to balance my blades (after watching a few Youtube videos)
Would it be too much to ask what you are working on?
Not everyone's crystal ball works as efficiently as we would like it to. Single cylinder engines vibrate more under load than multiple cylinder engines. |
Aside from balance and PTO.... Is there a chance one or more blades not properly tighten? And, yes, it would be nice to know what machine we're working on!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Yes, you do need to balance the blades & make sure they are installed right side up," & tight". Riding mowers with 2-3 blades can shake quite a bit with several blades unbalanced. Below is a short video that will help. The one thing I do differently, is that if I have sharpened the blade very well with nice edges, I don't " re-sharpen " the heavier side. Instead, I grind a little off the end of the blade to lighten it. I have a finishing nail hammered into a wall stud in my shop.
https://www.youtube.com/watch?v=d5bzlDNsGfI |
