Old 05-17-2012, 10:33 PM
derff96963 derff96963 is offline
Default Can't level Deck on Model 1215
I recently was lucky and purchased a Model 1215 with a 44" Deck. I have been fixing it up and getting is all into shape. Its going well except I have one issue.
The problem is I cannot get the deck to be level front to back. The front of the deck is too low and is chewing up the drive belt to the deck. I have adjusted the lifting links all the way up but the deck is still low in the front. The weird part is the deck stays tilted as you lift it up. Its only when it is almost the whole way up that is flattens out like it should be in the first place. I found a maintenance manual and everything is connected as the diagrams show except for the front deck support. The only difference here is the support is upside down from the pictures but is connected to the correct mounting holes. I have tried flipping it over but it hits the roller and can't be connected that way.
Anyone have an ideas? I am fresh out.....
