Old 08-18-2019, 09:09 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default k321 engine compression check
what is typical compression lbs. for a engine in good condition ...
100-120 lbs sound right ?
tks, B.
Old 08-19-2019, 07:51 AM
Inactive Member
Most K Series engines have a Automatic Compression Release (ACR) thus it is very difficult to get an accurate Compression number.
If you are in the 100-110 PSIG range, then I would say you are good.
Old 08-19-2019, 09:31 AM
And I would add if you are reading that high of a number, your compression release is not working, disabled, or the valves are not set correctly.
Old 08-20-2019, 01:24 PM
scgtguy's Avatar
Default k321
true ... im savy on the compression release ... tks for the info
B.
