Old 11-02-2023, 10:10 PM
Originalcub Originalcub is offline
Default Steering has lots of play
On my 61- 63 there is a good bit of play in the steering. Id say if you started at 12 o clock it would go to 2 until it hit a stopping point. Is that normal or is there a fix. Its been awhile since I looked at it but I believe there was just lot of spacing between the gearing.
Old 11-04-2023, 02:52 AM
69Cub124's Avatar
69Cub124 69Cub124 is offline
Post Axle link may be ovaled.
There's a pin where the linkage to the wheels from the steering and the actual hub for the driver side wheel is. usually if the front end is lacking of grease and it takes more to turn or if a wheel is stuck this pin would oval out causing play. the only fix I can think of is drilling the hole out and putting in a larger pin. or given on how my pin came out in pieces. a bolt or replacement pin of some kind. i attached a diagram of the front axle for some reference.
Old 11-04-2023, 12:14 PM
jbrewer's Avatar
jbrewer jbrewer is offline
12 o clock to 2 o clock isn't bad really. There's usually play in the 3 ball joints and also some in the steering box itself.
All are easily serviceable (especially the ball joints).
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
