Old 08-06-2022, 04:03 PM
wolfen's Avatar
wolfen wolfen is offline
Default LT1042 no start
I have a 1042 that that will not start. When I hook up a coil, all I have is old ones form other motors. I don't know if they work with Briggs or not, but they should since the mowers they come off of are Briggs engines here's what I have:
* Battery 12v
* wire from battery to key switch 12v
* from Key switch to solenoid 12v
* out to starter 0v
Any help is GREATLY appreciated cause I really want this old mower running again. It's the only one that I have ever had that's worth a damn.
LT1018 18hp Briggs IC.....love the cruise control
Old 08-06-2022, 09:32 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
The LT1042 came with a Kohler courage engine.
If it's been replaced with a Briggs & Stratton, there is no telling what else has been changed.
As for your starter solenoid, if 4 posts it can be tested by putting ground to one small terminal and 12v to the other small terminal, then it should engage and the 2 big terminals should be shorted together.
If you are using a 3 terminal solenoid, you ground the solenoid body and 12v goes to the small post.
Either solenoid, gets a big +12 to a big terminal and a big wire from the other big terminal to the starter.
Unless you have a Vanguard engine with the solenoid mounted on the starter? Then none of the last paragraph applies.
JD x475
