Old 09-13-2014, 07:12 PM
hondaxr hondaxr is offline
Default Welder?
I am NEW to welding, looking for a welder for under $300! What is the best all around welder for repairing things like TRUNNION REPAIR on tractor or patching a hole in muffler and other small projects?
Old 09-13-2014, 07:50 PM
Just my 2 cents but I'd look on c-list in the tools section. Try to get something that is setup for gas. Not sure your going to find a good unit for $300 but who knows.
Old 09-13-2014, 09:41 PM
I purchased my Hobart Handler 187 for $200 off CL.
Old 09-13-2014, 09:49 PM
IHinIN IHinIN is offline
A 120volt welder with a gas kit should be good for anything Cub related. I have an older Snap-On 120volt 110amp MIG welder that I've used for all of my Cub projects except for the few things I've TIG welded. You should be able to get a good deal on a used one. To get a quality new welder you'll easily spend $500 or more.
Old 09-14-2014, 12:10 AM
chris hall's Avatar
chris hall chris hall is offline
buy the best you can afford. if it means saving for a while to get a good brand name than do it. i have a miller 175 i paid $750.00 6 years ago that gets used almost everyday.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 09-14-2014, 03:11 AM
cubby102's Avatar
cubby102 cubby102 is offline
Everything ive had to do honestly ive been able to do with my little cheapy harbor freight flux core... requires a little more work to make it real pretty but anything from the trunion to frame cracks ive been able to take care of easily even used it to fix my snow blade undercarrage without issue... its by no meansa quality machine but hey for 90 bucks im not complaining
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
