M20S Starter
Looking for a trusted source you guys might recommend to purchase an aftermarket replacement starter for the M20S in my 2072. Kohler number is 52-098-06. I'm not interested in genuine Kohler at $300 plus, but don't want chinese junk either. There are many on E-bay in the $50 -$70 range but ??? Anybody had good luck and want to share your source? Thanks!
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I have bought from these people with very positive results.... http://www.motorcityreman.com/
I've been buying the Chinese ones from DB electrical for several years for my Kawasaki mule---it gets cranked WAY more than all the lawn mowers here combined. I'm not certain any of them went "bad" just maybe got worn to the point I have the same problem as the original Denso---makes a gosh awful grinding sound, but isn't grinding the flywheel. We tried running an extra ground cable straight from the battery to the starter mounting bolt, picked up the infamous Kawasaki relay kit for Deere mowers and added it---even turned the starter gear around on the flywheel. Worn out quite a few batteries too. I'm convinced the problem is a low voltage drop or something due to bad wiring/key switch. It sometimes goes 6 months without screwing up. I've decided to just live with it. Sorry to get so far off track, but I would recommend them.
