Old 11-04-2024, 11:07 AM
Overcamber Overcamber is offline
Default XT2 Enduro series 42” one headlight flickering ?
Hello All , this is my first post , thank you in advance for any help you can provide on this .
I bought this new in 2018 . It’s done my very well to date . So a couple weeks ago the right front headlight started flickering while cutting . Without running and with the key on it lights fine leading me to believe its vibration induced .
Looking at the wiring and what I’ve read , you must replace the complete harness and lights included ?
My question is : can the small wires going into the back of the headlight (led) be removed or serviced ? The left headlight (working flawless) is fed from the flickering (right side) which tells me there is a constant make or break on the provided power or ground going into the problem bulb ..
Thank you
Old 11-04-2024, 11:33 AM
ironman's Avatar
ironman ironman is offline
1. Remove the flickering bulb from it's socket.
2. Inspect the bulb contact and socket contacts for corrosion. Clean as necessary.
3. Replace bulb in socket and test.
4. If it doesn't flicker, HOORAY, you fixed it.
5. If it still flickers, swap the bulbs, right to left, left to right.
6. If the flicker follows the bulb, replace the bulb.
7. If the right still flickers, report back.
Old 11-04-2024, 11:43 AM
Ok thanks . I thought bulb was like a solid state type of bulb and not a replacement individual unit ?
Old 11-04-2024, 01:28 PM
ironman's Avatar
My bad. Looks like no bulbs but L.E.D.'s
Doesn't look swapable. but you should still first look for a loose or dirty connection on the one that is flickering.
Old 11-04-2024, 03:16 PM
Thx for the help .
Does anyone know if the actual wire inputs are serviceable?
Old 11-07-2024, 01:13 PM
Nobody has encountered this ? .. I guess I’ll have to report back with my findings ? ?
