Old 03-12-2014, 08:02 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
Default Dropping the front
Would you guys trust grade 8 bolts for the wheel spindles?
Bi-Polar Plowboy Plowboy X Press
Old 03-13-2014, 07:59 AM
I would.
Old 03-13-2014, 10:09 AM
I would.
Being series or just yanking my chain?
Old 03-13-2014, 10:30 AM
AdamMorris's Avatar
AdamMorris AdamMorris is offline
As long as you trust the weld holding them on, you should be fine.
122-Curently in pieces with a cracked frame. Will live very soon!
Fathers - 106 w/ QA36, blade, 38" deck
1211 w/ 44" deck and blade
O w/ non-trip blade
Old 03-13-2014, 10:37 AM
yeah. ill trust is
Old 03-13-2014, 10:59 AM
Bolts are not a true 1 inch in diameter, are they?
The fit may be a bit sloppy on the bearing. That may not matter for a puller, the wheels are usually not doing anything, anyway!!
Also, Grade 8 is an alloy steel, needing carefully selected welding techniques.
Welding is a little hard on the heat treat, also,,,,,,,,,,
I would use 1" diameter cold rolled steel.
Old 03-13-2014, 11:00 AM
Serious, Grade 8 is stronger than the factory axle. The welding is the important issue.
Old 03-13-2014, 04:33 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I just used grade 5 bolts if I'm going to make spindles. find a bolt with the shoulder length you need then shorten it up by cutting some of the threads off. it works, like the others have mentioned the weld will be the weak point
Old 03-13-2014, 10:05 PM
hdsdcouple's Avatar
I think I would worry more about my fingers under the fender than the bolts as a spindle. Looks like a great way to lose a bunch of fingers to me.
so many tractors, so little money
Old 03-13-2014, 10:24 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I was thinking the same thing.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1210 1250 1415 1420 1440 1450 1535 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3205 7265
