Old 06-05-2024, 07:44 PM
1811woody's Avatar
Default Starter clicks
I've had a long standing issue with my 1863 and now my new to me 2284 were the starter clicks when you hit the key. On my 1863 I thought it was just the brushes not making good contact and just dealt with it for all these years. When I bought my latest cub it was doing the same thing so I finally decided to do some investigating. What I found was it is a common issue even for the green ones so JD came up with a fix in the form of a relay kit, this kit is also available at Amazon pn AM107421. It turns out for whatever reason there is enough of a voltage drop at the starter relay that it won't allow the solenoid to engage the starter. I hope this helps you guys that are having this problem.
Old 06-06-2024, 06:30 AM
Yep old issue, here is the fix from 2015
https://www.onlycubcadets.net/forum/...=starter+relay
Old 06-06-2024, 01:55 PM
1811woody's Avatar
I figured someone else knew about the issue and the fix, That is a great write up.
