Old 04-15-2013, 02:16 AM
Mainecubcadet108's Avatar
Mainecubcadet108 Mainecubcadet108 is offline
Default Rear weight bracket help
Last year we used a tray in the bottom of the tractor to put lead blocks in.This year i put a mid mount for hanging suitcase weights,but i need to figure out how to build a weight rack on the rear for suitcase weights.Just so you know we pull 900 1100 and 1300 pound classes.Nine hundred pound class really isnt the problem when we need the weight in the rear.It's when we get to the 1300 pound because there is alot of weights on the back of these tractors and i can't for the life of me figure out how to make it and hold a couple hundred pounds or so and not interfer with dropping the hook onto the hitch.Thanks in advance
Current tractor my son and i have
1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp
1980 whelhorse b-82 need restore
1976 simplicity 7116 all restored waiting for a new motor (my sons tractor)
1967 sears super 12 (my sons tractor)
1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago
Old 04-15-2013, 05:09 PM
austin8214's Avatar
When I get home I'll post a picture of mine for you.
Old 04-15-2013, 08:17 PM
austin8214's Avatar
I added the picture to my album. You can check it out there. I can't get it to load here for some reason. If you have any questions just let me know. I can get some more pictures later.
Old 04-15-2013, 08:43 PM
Thanks Austin.nice puller by the way.Did you bolt or weld it to the frame and thats what im looking for.Dont want to be a pain do you have a photo from the rear.Thanks
Old 04-15-2013, 10:37 PM
austin8214's Avatar
I used the existing bolts that bolt the seat pan to the frame. I will post another picture when I get home from work.
Old 04-16-2013, 11:04 AM
austin8214's Avatar
Here you go.
Old 10-22-2015, 02:16 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
I will be pulling in a 950 and possibly 1100 class. I have 50 lbs wheel weights. I want to know your opinions on wheel weights compared to suit case weights in the rear. I understand there would be rotating mass in the rims but it also lowers the center of gravity. So I was wondering what people think and have experienced. Thank you
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 10-22-2015, 06:49 PM
austin8214's Avatar
It's best to keep the weight as low and tight as you can. I recommend getting an under transmission box and fill that first with as much as you can. If you are pulling stock class I don't think the extra rotating weight has much effect but if you get up in the higher wheel speed stuff it definitely makes a difference.
Old 10-22-2015, 11:42 PM
CumminSHO's Avatar
I agree, with the faster wheel speed the harder it will be on the transmission ad drivetrain. As I progress in classes I plan on upgrading the weight brackets with a mid mount weight and rear weight bracket. As well as many other things. I want to get my drivetrain set up properly first.
Brinly 10" plow
42" deck
Old 10-25-2015, 05:22 PM
bschmittling bschmittling is offline
Originally Posted by austin8214 View Post
Here you go.
Any chance you could make another of those to sell? If you are interested, just PM me with a price.
