Steering Broke!
well its way too cold to deal with it, but while moving a trailer (with another cub in it!) (which also doesnt steer) I heard a snap, and the steering wheel just spins around. It's not the drag link, its inside the box maybe. What usually goes in there? Is there a heavy duty upgrade?
Just askin here, cuz its too cold to take it apart just now..
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
very cool thanks. but what usually breaks? (or is there not a usual suspect)
I would guess, because you state that the steering wheel can just spin, that the cam follower may have snapped, That or the pivot shaft for the side plate.
The cam follower is a pretty easy part to replace as it screws in, side plate and pivot shaft not so much. You'd need to find a complete used replacement. Best you can do is take it apart and find out!
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
Yup, when it gets warmer out I will!
hey anyone know the steering ratio off hand?
I had that happen on my 122. Not as lucky as you, I was in the middle of main street downtown using it for handing out water before a parade started. There was a loud stiff snap, the steering wheel started spinning freely, and even pulled up out of the shaft about two feet.
I opted to replace the whole thing, and when I got the old one out I decided to dismantle the broken one out of curiousity. I pulled out a bunch of stiff old grease, a few loose ball bearings, and some metal shrapnel. Let us know what you find when you get into it!
It all started with a little 122...... |
Can you lift up on your steering wheel and have it slide up? If so, it's the shaft itself.
Hard to imagine the follower snapping. I just ordered a replacement (see "Rabbit hole" thread :-) ) . It would seem one of the strongest parts of the chain of events, but I suppose it's possible. The box itself can break too as it's cast aluminum I'm pretty sure.
You guys are making me go down the rabbit hole now...
With all this steering talk, and my 107's dash tower already removed, I may as well pull the steering box for a quick rebuild while I can, right? Certainly wouldn't want it to break on me while I'm in the middle of something... right?
