Old 09-08-2018, 10:44 AM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default Now what...more electrical issues
While mowing, the nut fell off of a deck wheel on the 1250. Pulled into the garage and shut it off. Put the wheel back on, turned the key and nothing! No click. No response, nothing. Maybe the brake safety switch. You can hear the PTO click on.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 09-08-2018, 10:53 AM
Is the PTO switch completely off? I would assume it's a safety or loose connection, time to get out the meter and start testing.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-08-2018, 11:14 AM
Inactive Member
This is what I would check first also.
Old 09-08-2018, 11:49 AM
RChristensen RChristensen is offline
Inactive Member
Sound like the old “wiggle the PTO switch while turning the start switch”. Seen a lot of those, almost like a safety switch to keep people from starting a cub if they didn’t know the trick.
Old 09-08-2018, 11:51 AM
cooperino's Avatar
Yup.. If ya hear the PTO click when ya turn on the key she not gonna crank.
Old 09-08-2018, 12:50 PM
bllwnkl's Avatar
There is no noise when you turn the key. With the key on, I flipped the PTO switch and heard it click on. Makes me assume that the PTO switch is working.
Randy
Old 09-08-2018, 01:09 PM
cooperino's Avatar
Ok... so you have power. Did you check that neutral switch is being met?
Old 09-08-2018, 01:37 PM
jbrewer's Avatar
jbrewer jbrewer is offline
...and basics.... what's the voltage on the battery?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 09-08-2018, 01:38 PM
I think your right.
Turn the key to the start position and then jiggle the pto switch when it is in the off position.
Still no starty?, start checking the connections with a meter.
Up to 530 and counting...
Old 09-08-2018, 02:26 PM
Inactive Member
The ONLY other device in the start circuit is the left hand Pedal (Neutral Safety) Switch. Either the switch is bad or the wiring to it.
