Cub Cadet 1200 fuel tank
I am working on a Cub 1200 for a friend. It’s been sitting several years. I got the Kohler K301 running very well b7t the fuel tank is leaking. It appears to be the fuel shut-off valve. It pushes into a rubber seal and into a plastic fuel tank. I have ordered new parts, but my question is can I put some kind of sealant around the rubber seal to help it seal ?
Thanks Ted |
No need to do that. Just put some oil on the bung, push it in the tank and then lube up the fuel shut off valve before pushing it in. Then you should be good for a few years.
Thanks. I will do that
TB |
It worked. Thanks
