Greg Rozar AKA- CubDieselFan
Old 05-10-2022, 02:17 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default 149 hydro too fast in reverse
Still working on my friend's 149. Thanks for all the help I have received so far. The tractor moves smoothly when going from neutral to forward. When going to reverse, it is sorta jerky and moves in reverse too quickly. Goes too fast too quick. Hydro fluid has been changed with travellers premium and new NAPA filter 1410. Took the relief valves from my 149 and put in tractor being worked on. Nothing changed. Any help will be greatly appreciated. Thanks and have a great day.
Bob
Old 05-10-2022, 02:43 PM
I'd take a look at the linkage from the dash all the way to the trunnion shaft. I'm gonna bet something is worn.
Old 05-11-2022, 11:48 AM
Farmall450's Avatar
^^^ Or several things
Old 05-13-2022, 09:14 AM
Mr Bob's Avatar
Default 149 too fast in reverse
Thanks for the reply's. I can't see anything extremely worn on the linkage. Nothing jumps out but being over 50 years old I am sure all the linkage is worn. Going to adjust the brakes, find and lock in true neutral and then adjust linkage. Hopefully that will help and not make it worse. Going to try to work on it today. Will let you know how it turns out. Thanks and have a great day.
Bob
