Old 03-26-2021, 09:48 AM
CubbyRI CubbyRI is offline
Default Steering box gasket thickness???
hi all,
I bought this gasket and wondering if its thick enough b4 I install it. It looks like the metal lip would hit before the gasket gets to compress. But maybe I got it figured all wrong...
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 03-26-2021, 10:00 AM
ironman's Avatar
ironman ironman is offline
Last time I worked on one, the lip of the cover extends down over the side of the aluminum case so it doesn't stop any compression of the gasket.
In any event it's only grease, not oil, and it's not under pressure unless you pump 10 lbs. in there.l
Old 03-26-2021, 10:09 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Yep... no worries. It's certainly not there to seal anything under pressure that's for sure. Chassis grease isn't going to go anywhere fast even with just that wimpy "seal"
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-26-2021, 10:52 AM
ok thanks guys...
Old 03-26-2021, 11:59 AM
Merk Merk is offline
The gasket piece should be a foam gasket.
They are nla from Cub Cadet.
The early John Deere garden tractor used the same steering box-assembly.
John Deere part numbers are
Retainer-M45569
Seal-M45568
Project Uncle Dick
Cub Cadet 70
Old 03-26-2021, 12:03 PM
I've used packing foam to make a gasket-seal
Project Uncle Dick
Cub Cadet 70
Old 03-26-2021, 12:25 PM
ironman's Avatar
Ditto! It is said that "great minds think alike".
Old 03-26-2021, 01:13 PM
Same here only used thin sill sealer foam.
Best to clamp the ass'y in a vise, attach the steering wheel and then adjust it for best firm feel w/o binding.
Be sure and run it back and forth through several cycles while adjusting for best results,
Old 03-26-2021, 01:25 PM
mortten mortten is offline
I’ve used that also.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 03-26-2021, 02:27 PM
l
You are, as usual, correct sir...
