Old 07-13-2013, 06:03 PM
iroccrazy iroccrazy is offline
Default Help needed on 3184 Cub
Hello all ,
I have a problem with a Cub 3000 series and maybe you fine folks can give me some ideas on where to look . I've owned this tractor for about 5 years now. It always performs like a champ, until recently. I went out and tried to start it - it will fire up and shut right off, or might run for a few seconds with the choke closed , then shuts off .
Things i have done to try and remedy
* New fuel line carb to gas tank ( new fuel filter )
* New plugs
* New gas in tank
I see the fuel is laying about level in the fuel filter. Does anyone think I should try a new fuel pump? Thanks in advance.
Jim
Old 07-13-2013, 06:59 PM
rweaver rweaver is offline
the place I would look is the fuel shutoff built in the carb with the junk gas we have it can get stuck of quit working see if you pour gas in it keeps running
Old 07-13-2013, 09:05 PM
just came back in , tried going directly in carb with a syringe . it would run until i stop squirting then quit running . what does this mean is my problem the fuel shut off ? if it has a single wire going to it - it looks rather hard to get at to take off to clean /replace . I have the entire air cleaner assembly off at the moment
Old 07-13-2013, 10:26 PM
I think you were spot on with fuel shut off selinoid , took it off , drop of 3-in-oil in it and it fired right up . I am going to order in a new fuel shut off monday morning just to have a spare . thanks so much rweaver
this forum is full of priceless info when your ready to throw wrenches
thanks again
Old 07-14-2013, 08:16 AM
Try to find ethanol free gas and put some Sea-Foam in it. It will help clean up the deposits from the crappy gas.
Old 07-14-2013, 10:09 AM
I had a solenoid stick a couple years ago on a CH 18. Took it off and shot some brake cleaner in it and in the receiving end of the carb. Been working right ever since. You should be able to feel/hear that thing click when you cycle the key on/off. If it clicks, it's likely working but the passage that pin shoots into can get dirty and still shut you down.
I have found that E 10 gasoline is actually a pretty good solvent and keeps the fuel systems clean as long as you keep the water out of it. Water in E 10 can form a corrosive sludge and can stop up/eat up your carburetor.
Old 07-14-2013, 03:11 PM
Thanks guys , I will try some sea-foam and maybe just stick the new selinoid on while i'm in there thanks again Jim
