Carb float setting Kohler Command 18
Anyone know the dimension off the top of their head?
The M-18 Service Manual is in the Technical Library section on page 3.
Not the same carb.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Well I guess I can't be positive but I'm pretty sure a CH has a different carb than a M 18. Mine do
The correct float height adjustment is 22 mm (0.86 in) measured from the float bottom to the air horn casting.
Note: Be sure to measure from the casting surface, not the rubber gasket surface.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Opps.....My Bad. I mis-read his title and thought he had a M-18.
Defiantly different.
Thanks! I was needing that number too.
Thanks, I had it once and lost it. I'll write it down now.
