Old 07-03-2009, 09:37 PM
fer100's Avatar
fer100 fer100 is offline
Default Clutch Spring compression tool
wanted to make this out of channel iron like I was instructed to but I tried to drill into the channel iron that I got at tractor supply but could not get a hole into it (spent $60.00 in different drill bits) So I gave up. I used this metal I had laying around instead. I just wanted some imput to see if every one thinks this will work or am I going to kill myself. How much pressure is clutch spring holding?
Old 07-03-2009, 10:31 PM
It's gonna flex a bit, but with a stock clutch spring, you should be alright. The stock springs are about 250-300#/in. of compression.
Old 07-03-2009, 11:05 PM
fer100's Avatar
I guess I'll give it a try this weekend and see if it works. I still have to get the clutch off the tractor. I am in the begining stages of setting up a shop don't have all the right equipment. I have to go out and buy things as I go. Any tricks to drilling in channel iron. My jig saw cuts through it like its butter but When i drill it it won't even mark it . I've tried slow, fast speeds oil as i go. Cobalt bits, high speed bits,tried it with a small bench press and a hand drill. I'll keep you posted
Old 07-11-2009, 09:06 PM
fer100's Avatar
matt G I finally got the cluch out and the tool worked fine. like you said it flexed but worked. If I would do this all the time I would make a better tool. Thanks for the imput
Old 07-11-2009, 10:58 PM
Merk Merk is offline
Here is the clutch tool I use to rebuild clutches:
Clutch spring is compress....ready to remove pin
Business end on my punch I use to remove pin
It was purchase from Sears.
Old 07-12-2009, 12:52 AM
fer100's Avatar
I like your set up it alot easier to work with. I look at the spiral pin punch set at sears fri $19.99. but couldn't use it when i was trying to removal pin in shaft to remove clutch to short. I didn't think about afterwards to remove the spring and other parts. will go back and get it for my tool box. Thanks for the imput.
Old 07-12-2009, 08:20 AM
MBounds's Avatar
MBounds MBounds is offline
FER100: Just like wrenches, those Roll Pin punches do come in more than one size....try buying the whole set and then you can remove any of the pins...just use the right size ..
Myron B
Old 07-12-2009, 09:01 AM
fer100's Avatar
I understand the short set is all sears had on display. I'am going back today and get that set and pick up there tool catalog. I also i'm going to start hitting some auctions and try to start to build a shop. Like getting a welder , build a work table. I have a large sears compressor and alot of the air tools already. I need to build a work bench in garage also. Up here in watertown I keep my tools in the basement winters are cold and with snow storms dropping any where from 3 feet to 5 feet of snow per storm i need to keep garage empty for the cars.
