Old 02-19-2016, 11:24 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Question Cub Cadet 1772 Implement Lift
Is there a way to measure or a documented procedure the amount of lift "strength" of the implement lift on a 1772? Whil the cylinder does move, it seems to have limited range of lift when I have the 60" Haban mower on it. The rear mount on the Haban is different than other Habans I have in the "fleet". Most of the Habans I have use spring loaded attachment pins on the rear mount, while the Haban I have on the 1772, has a series of holes through which a shaft with hairpin clips on either end mount the Haban to the implement lift.
The first thing I want to find out if the lift is working properly and if there's some way to test it.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-19-2016, 11:55 AM
Frank
Can't help with a method to check your lift other than a pressure test of the hydraulic system. As far as the mounts on the Haban decks it seems like they changed the design on the fly. I've seen 3 or 4 different designs for the rear part of the deck attachment. Some have the spring loaded pins and some have a solid rod.
Old 02-19-2016, 02:18 PM
aagitch's Avatar
aagitch aagitch is offline
The habans I've had didn't raise very high. The hydro system had plenty of pressure I just think there's not much clearance for them to lift very high
Adrian
2072 (789513)
Old 02-19-2016, 08:08 PM
V30crewcab V30crewcab is offline
my haban on the 1782 doesn't lift high either. just nowhere for it to go!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-19-2016, 11:49 PM
X-2. Same with my 1872, nature of the beast I guess.
Old 02-20-2016, 08:23 AM
john hall's Avatar
X3, deck on my 2072 doesn't clear the ground well enough to travel fast down a gravel drive. I think this is why so many folks let the tractor carry those heavy decks on the frame, resulting in all the severe wear folks find. In other words, design flaw by CCC.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-20-2016, 05:25 PM
FrankF3's Avatar
Yea, clearance is very limited. On my 1572 I can get it to lift the Haban 60" deck so I can get 3 -4 inches of clearance between the wheels and the ground. On the 1772, while i can see the weight unloading off of the wheels, I can't get it to rise up high enough to get any clearance between the ground and the wheels like with the 1572.
Old 02-20-2016, 07:06 PM
are the lift links adjusted the same between the two?
72 scout
IH 404 tractor
Old 02-21-2016, 12:53 AM
For a comparison. On our gravel driveway, going anything other than super slow I can hear the rear deck wheels hitting the gravel stones with the deck as high as possible...
Old 02-21-2016, 09:57 AM
john hall's Avatar
That's about how my 2072 does. Its been a long time since we put it under the machine but I think we had everything adjusted to go as high as possible without hitting the frame/mule drive, I seem to remember that being a problem.
2072 w/60" Haban
