Old 04-07-2015, 08:48 PM
cyr2872's Avatar
cyr2872 cyr2872 is offline
Default Tiller Adapter for the 1872
A few guys have posted their adapters on here. I finally got mine made up the last couple days.
Marking the gearbox placement.
Plate that attaches to the tractor.
Plate with pins to bolt onto the gearbox. I tried to use all existing bolt holes but ended up drilling 2 more for added support
- Jason
________________________________
1872 - Kohler 28hp EFI repower
Old 04-07-2015, 08:50 PM
cyr2872's Avatar
Added the arm to use the center pin.
The two plates mated together.
Test fit on the gear box.
- Jason
Old 04-08-2015, 06:36 AM
Leadslingingdaddy's Avatar
What tiller are you using????
The Self Powered CC or a sleeve hitch style?
Just wondering since I don't think the belt driven tillers would cover the rear tires..? Maybe I'm wrong on that one ....
Old 04-08-2015, 11:06 AM
gt383mag's Avatar
gt383mag gt383mag is offline
need more pics
Old 04-08-2015, 11:18 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Looks like a #1 or 2 tiller the belts will be fun.
Old 04-09-2015, 11:56 AM
cyr2872's Avatar
Yeah, I thought about that. It's a #1 with both extensions which makes it about 40" wide. Outside of rear tires is about 42" so there'll be a little overhang. I'll see how the mounting goes. More pics to come!
- Jason
Old 04-09-2015, 11:57 AM
cyr2872's Avatar
You bet! I have a few ideas
- Jason
Old 04-09-2015, 07:32 PM
Redblower's Avatar
Redblower Redblower is offline
Nice work, looking forward to seeing more!
Vic
Old 04-17-2015, 10:32 PM
cyr2872's Avatar
Well I finally got to work on the adapter some more.
Mocking the tiller up to the back to make the lift arms
I didn't want to weld anything to the tiller so I made an attachment point that utilized the original holes where the chain lift went for a sleeve hitch. It's some left over 3/4" rod and 2" angle iron I had from another project.
Lift arms made from 1.5" flat steel, also from another project.
Top view:
Lifts pretty good!
After I picked up a belt that was too long...then a belt that was too short...I found the perfect length. Gates B173 which is 176" outside length.
Underneath view of the belt.
- Jason
Old 04-18-2015, 08:23 AM
That looks like a sweet setup. Looking forward to your report about how it works.
