Old 01-15-2015, 08:09 AM
Thomas Hooper Thomas Hooper is offline
Default Cub Cadet 72
I am putting a kohler 8hp internal starter/magneto charging system on a CC 72. I need help on wiring it up. Tom
Old 01-15-2015, 11:00 AM
IIRC, use the wiring diagram for Quiet Line series tractors.
I believe it's easiest to use a QL ignition switch so that the voltage regulator is isolated when the key is off.
If you are not using an electric PTO, eliminate the PTO switch, "S" goes to safety switch then to solenoid.
Everything else is the same as the diagram shows.
Old 01-15-2015, 07:52 PM
Welcome to the yellow fever.
let see some pics of your engine.
Up to 530 and counting...
Old 01-15-2015, 08:17 PM
Tom is no stanger to the yellow. I can email you a wiring schematic if you need me to Tom.
