What primer for iron guard paint that's not from case/IH?
I'm about to shoot the sheet metal for my tractor. I have case/IH ironguard paint, hardener, and thinner, which have worked great through my HVLP gun. So far I've only used Rustoleum primer and the paint was worked fine so far. The fender pan and hood are a little too big to prime with a rattle can. Is there a primer I can use that's compatible without having to drive 3 hours round trip to the nearest Case/IH dealer?
1973 Cub Cadet 149 2023 John Deere X590 Farmall B sitting in relative's barn |
I use ppg primer under the case/ih paint all the time with no issue. Just about any 2 component primer will be fine since its fully cured before it top coated, most incompatibility issues come from wet on wet application.
Tim,
What's a 2 part primer? Thinner and primer? Any certain type of PPG primer?
2 part will be a primer with a hardener/activator. ppg's shopline brand has a cheap primer that works pretty good, its # is jp285
