Old 06-26-2022, 06:15 PM
gdheck's Avatar
gdheck gdheck is offline
Default PTO clutch for my 1782
I'm having a problem with the PTO clutch on my 1782. Unfortunately, I have zero experience with electric PTO clutches, because I have never had a problem with one. It will work fine for maybe an hour then I believe if shuts off and starts lugging the engine down. It's kind of hard to tell, because I have to get the PTO switch shut off fast to keep the engine from shutting down. I can shut the switch off, let the engine come back up to speed and it might not do it again or it might do it within a few seconds. It mostly, but not always, does this as I shift from forward to reverse. Any thoughts?
Also what does everyone recommend for replacement clutches? I see them for anywhere from around $125 to over $500.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 06-26-2022, 10:18 PM
CubDieselFan's Avatar
What deck are you using. What you are describing, sounds like to me could be a deck spindle binding.
Old 06-27-2022, 10:06 AM
gdheck's Avatar
It's a 60" that I completely rebuilt a few years ago and keep pretty well maintained. This is its 8th mowing season. I'll take the belts off and see how it feels and grease it again before I mow next time.
Now that you mentioned that, about the only thing that didn't get replaced during the rebuild are the mule drive pulleys. I guess I'll start my checking with them.
