Sweepster
I am looking at a sweepster tomorrow. It has an electric motor on it. I've never seen one that was electric. Does anyone know if this is original? Here is a pic of it. I am picking it up in the morning[
Original, 1512, ih 982, ih 682 |
I've seen one or two on marketplace, but I've always assumed they were belt driven.
The best ones are actually hydraulic, but not for Cub Cadets
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I have very similar (same model) sweepster on one of my 129's. The electric motor for mine is for the electric lift for the unit but not the drive unit. Mine is chain driven. Congratulations on acquiring one!
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
OP, did you end up buying it?
Mine sticks out several feet from the front of my tractor, which made it very front end heavy and I could lift the back of my tractor with just one hand, so you will likely need to add weight to the rear of your tractor to balance. It sure makes leaf removal fun!
