Quick attach on 122....
Ok so I know the basic answer is anything can be fabricated, but has anyone made or put a quick attach on a 122 or similar?
just buy a 1x4 frame and switch everything over.
I was thinking of something like that, but i would realy like to make it a QA without switching out frame.
I used my QA-42 on my former 122 simply by using those straps to bolt it up. It worked perfectly
I think it's easier to put the blade on my 102 with Jeff's pins than my 782. Every time I raise the front up to lock the pins in the ears fall of the back. Maybe I am not holding my mouth right.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
One of My 100s has a front blade, mower and a center blade that are installed at different times.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I get that, but what I'm asking is has anyone put a QA on a 122. I don't realy care about what is easy. I don't have a problem bolting an attachment up, i just want to do,it, to do, IT.
I think you want to put a qa mounting system on the 122 like a 125 has.Am I correct?
