Old 07-13-2016, 05:07 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Default Anyone ever speed up a 48" IH deck?
Ever since i cut my lawn with a 782/50c i was so amazed with how well the lawn looked when i was done that ive been searching for a way to speed up the 48. Ive seen a lot of guys speed up the 44/50" decks but what about the IH 48 with cast nose? i always heard the older cub decks spin slower then other colored decks so, i did a blade tip speed check with a laser tach. I wound up with 3560 RPM at the blades tip which matched exactly to the engine RPM on the 127. (i guess that's what cub was aiming for). is there a pulley out there that i can get to speed these blades up?
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-13-2016, 09:23 PM
There is a speed up pulley that went in the center of the deck- IE the one that accepts the belt from the engine and also drives the belt for the other two blades. IMO I've used both the 50" deck and a 48" and while the 50" throws grass farther the 48" cuts better because (I think) it's taller. I prefer the 48" triangle cast iron center decks.
Old 07-13-2016, 10:18 PM
There is no speed up pulley for the triangle decks.
Nice to see you again Ken!
Old 07-14-2016, 07:05 AM
I was thinking about this thread when I remembered seeing something about a "speed up pulley"....http://www.onlycubcadets.net/forum/s...t=speed+pulley
Old 07-14-2016, 01:47 PM
ken6x6's Avatar
well shoot, looks like im going to have to make my own. ill try getting an OEM center pulley and split it and see if i cant mate up a smaller one on the top section. anyone know the size the "speed up" pulleys are for the 44" decks? i think that would be a go size to start with.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-14-2016, 02:32 PM
Just so we are all on the same page here, you want to speed up a cast nose "triangle" deck. Is that correct?
Old 07-14-2016, 02:37 PM
This is totally off topic but I went Saturday to pick up a Ford tractor for work and it turns out that it's yours, I like your dad's super.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-14-2016, 03:03 PM
ken6x6's Avatar
yes the 48" cast nose triangle deck i want to speed up.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-14-2016, 03:07 PM
ken6x6's Avatar
oh wow, that's pretty ironic. yup that old ford needs a lot of help. hows it coming along?
That super in the barn had a loader and backhoe on it at one time then i switched it all over to a diesel.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-14-2016, 03:56 PM
coming along good so far.
Pap's 100
Restored 108
1211 Dual Stick
1050
