Old 12-06-2016, 01:16 PM
cobra2411 cobra2411 is offline
Default Early Lift Arm
I picked up a QA36A Snow Thrower that came off a later WF. I have the QA adapter on my 124 so that part was easy. The later lift arm wasn't going to work...
So I made one...
Works great. I added an assist spring too, but I think I need to modify it for a little more tension. It helps, but not as much as I would have hoped. Not sure where the lift arm came from but it was cut and welded and was way to short. So... I cut and rewelded it longer. I may have to try and make a new one because it looks horrible. But it works...
Old 12-11-2016, 09:12 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
if you cant find the right one... build it.
i made a "lift assist" for my blower last year. i used a trunk lift support that was rated at 110lbs of lift. id say it cut off about half the strength required to lift the blower.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 12-11-2016, 09:42 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Looks good.
Old 12-11-2016, 09:47 AM
Tom4981's Avatar
Here's a photo of spring assist , looks simple enough .
