Old 01-01-2023, 05:03 PM
CubVideoCadet CubVideoCadet is offline
Default 1650 Ignition Problems - Don't Make Expensive Assumptions
Thanks to the helpful information in various threads, I was able to diagnose the no-start problem on my 1650. Before consulting the forum however, I first bought a new ignition switch. The new switch didn't fix the problem, so I was about to order a solenoid, and then I thought that maybe the forum could help...
It was corrosion in the positive cable inside the eyelet at the terminal. A little baking soda and water did the trick. Thank you!
Old 01-01-2023, 05:19 PM
Inactive Member
Good to hear that you found the problem.
Old 01-01-2023, 07:52 PM
Common issue with the QL's.
Especially if they spend a lot of time getting wet.
Direct path for water to get to the ignition switch, right down through the slot for the hydro lever
Old 01-04-2023, 06:06 PM
To clarify, it was the positive battery cable at the battery end. I took the cable off and dunked the cable eyelet in a cup of baking soda and water a few times until the bubbling stopped. It left a good bit of crud in the bottom of the cup when I was done.
