powdercoated decks
anyone out there using a powdercoated mower deck? Im getting ready to have mine done, but was curious. I would not expect grass to not stick any less but It should last longer than paint.
I fully understand the process, but underneath a deck.. such as mine.. it was primered, painted, and used. Now its pitted rusted, wear cleaned metal. Probably best to call it grasscoating now. I cant prevent the chipping, but overall, I think the powdercoating will outlast the paint. Agree, or disagree? Cost is low, and general wear is highly resistant. Seems logical to me.
If it sticks better than CCC's '90s powdercoat, you might be ok. I think all of the cyclops tractors and attachments are powdercoated. The quality is very inconsistent at best. I have had parts that the coating would easily peel in one area and be next to impossible to remove a couple inches away. It certainly didn't look to be more durable than paint, judging by the decks from that era that I have had in the past.
If it were mine, I would wire wheel/sandblast/etc. all of the rust and loose chunks and just use normal paint. I use a product made by Rustoleum that can be applied over rust, and it has worked pretty good. I have it on the bottom of a couple decks and also inside my loader bucket. It is brushed on and goes on nice and thick. It will wear off in a few areas, but if the deck is kept clean, it won't rust. If you scrape the underside of the deck frequently, mow only when the grass is dry, etc. you won't have rust issues. |
new parts in production are coated in lubricants, left from stamping/ forming/ light machining. Mostly oils that werent fully cleaned off.
Aftermarket powdercoating is paid more attention and also, is freshly sandblasted clean in a non production environment that yields better , more consistent results. high production yields low quality. its a horrible fact. Price exponentially affects that equation. |
Not too long ago someone posted pictures of a deck that they "painted" with spray on truck bed liner. It looked like a rubbery coating. I think that would be better than paint OR powdercoat (wish I knew where that post is).
Just out of curiosity = what about using epoxy paint? My old job we used it on the bridges in nyc and that stuff is hard and takes a beating!!!! Just a thought?
BRIAN |
I plan on coating my deck with Herculiner truck bed coating.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Clean it really good, buy cheap rustoleum paint, and paint it. After it's dry coat it with used motor oil. and let it soak in. do that twice a year and it will look as good as new for a long time. I have a deck that was my dad's that has been in our family since new and it looks new from having that done to it. It has more rust on top than on the bottom. I haven't cleaned it from last summer yet and this is all the grass that's under it right now. It's a very low cost way to take care of a deck. Doesn't look to bad for a deck that was new in 1984!
2013 cub cadet GTX 2100 w/IH weights 1984 cub cadet 1282 w/#2 cart, plow, IH weights 1970 IH cub cadet 73 w/fenders Haban 402d sickle bar 1966 IH cub cadet 102x2 1966 IH cub cadet 71 pull start w/Fenders IH sweeper, Brinly Gard N Cart 1965 IH cub cadet 100 w/Fenders hydro lift Brinly Gard N Cart, 3 point sleeve hitch Brinly plow sleeve hitch blade #1 cart 1965 IH cub cadet 70 w/fenders and snow plow 1961 IH Cub Cadet Original #3646 w/fenders 3 point, IH rear blade, non trip snow plow |
That is one really really clean deck!! Juniors, you have the most succesful idea I have ever seen! I am amazed that the grass isn't clumped up around bolts, or spindles. I am still powdercoating it , but I could add to it on bottom side with any of these great ideas.
