Lawn Sweeper
I have your typical Lawn Sweeper (Agri-Fab). It works fine. I am looking for a tip or trick for this. When the bag or hopper gets full, then I am off "unloading area" to dump my load. Is there a way to turn off the "brush assembly" while go to/from the sweeping area.
Not that I'm aware of, every sweeper I've messed with has had a direct gear drive from the wheel to the brushes.
No, sure isn't. I got tired if driving around with it running to unload also, so I dump all the grass in piles near where I'm sweeping, then go back with a wagon/cart and pick them up. If your sweeping leaves, that may be counter productive though....
Leaves is not the major issue...........Pine Needles is..!!!
Seems some one would come up with something to turn the brush on/off.
My uncle had one with a lever that would disengage the brush but I don't remember what brand it was.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
If you go in reverse or hitch the sweeper to the font of the tractor the brushes freewheel.
Get a blower/bagger set up instead.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
It doesn't seem as productive but you gotta sweep away from the dump site and then back to it again, dump when you're there and go again. If you can get two rounds before you're full, all the better.
Make it mount to your 3pt hitch and raise it up... thats my solution
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
How good are you at backing up?
