Old 10-27-2023, 10:43 AM
cubavi8tor's Avatar
cubavi8tor cubavi8tor is offline
Default 682 smokes!
So I bought a 682 at an auction that leaked gas everywhere, I replaced the fuel pump and that took care of it. Also changed oil. Now it runs great as ever but when I shut it down it smokes for a few minutes and seems hot. It only smokes after I shut it down. Any ideas?
Old 10-27-2023, 12:11 PM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
you try degreasing motor as best you can first . try the old white powder trick look for seepage. see where leads too. just an idea.
Old 10-27-2023, 02:28 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
I agree with jcubtroy. Degrease the engine and look for a potential oil leak.
IH Cub Cadet 70, bought for $50, has Case fenders, several new parts got it running/driving, 2nd gear doesn’t work, currently rebuilding motor, 38” mower deck
Old 10-28-2023, 10:57 AM
cubavi8tor's Avatar
Thanks for the info, it could definitely be from the gunk that’s accumulated underneath. With the fuel pump leaking like it was when I bought it, that junk is probably soaked in gas. A good cleaning is definitely a good start.Now to find the time…⏳
Old 10-28-2023, 12:21 PM
Pull the engine out of the tractor, remove all of the tin work and give it a through cleaning. I wouldn't be surprised if you find a mouse nest that is blocking the air flow needed for cooling.
Old 11-01-2023, 10:30 PM
Great idea so you don't overheat the engine and do any further damage to the heads.
