Old 04-25-2021, 01:45 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
Default New carb or Kit? Faded Serial # for Command?
I just purchased Another 1864
The seller was very nice and Honest with me.
It had been sitting in storage and the gas went stale.
It has a Kohler Command on it.
I want to take the carb off and clean it or replace it if needed.
Where is the best place to get a kit?
Or is there a Good New carb I could buy and just bolt on and go?
The tractor model is 144-684-100 and is a High 850000 serial #
Here's is the (Main) reason for the post.
The serial #on the engine is almost gone picture below.
I have an 1863 that has a Kohler Command.
The serial # is in a different location and readable.
Are the Carburetors different?
Old 04-27-2021, 09:06 PM
CubDieselFan's Avatar
They are the same. Same Kroller spec #.
Old 04-27-2021, 10:47 PM
Thanks for the info.
I have yet to pull this in the sunlight and try to document what I can still See.
Some of the numbers are still legible with a Maginifying glass.
I put Sea Foam in the gas.
It has not kicked in yet
Now I think I will start with a Kit.
Thanks a Lot
Old 04-28-2021, 06:59 AM
ironman's Avatar
ironman ironman is offline
I saw this carb rebuilding/cleaning video on YouTube.
I have yet to try it but I intend to.
Maybe it will help you.
https://www.youtube.com/watch?v=_Y23cfaH4hE
Old 04-28-2021, 07:36 AM
ejl6658 ejl6658 is offline
I had a carb on a Kohler CH20 that would cause engine surging above idle. After multiple cleanings I could not rectify the issue. I purchased this carb off of ebay and it worked great right out of the box. Hope this helps.
http://www.ebay.com/itm/353360470634
Old 04-28-2021, 11:41 PM
Thank You so Much.
That is a Great video.
I normally use this.
Link:https://www.zoro.com/gunk-carburetor...All%20Products
I will try the Muritic acid /For sure.
If you spill some on a Gravel drive way
It looks like a Dog Foaming at The Mouth
Ask me how I know
Thanks for the help.
Old 04-28-2021, 11:51 PM
I think I will purchase That.
This is probably the (Ticket)
I will still try to refurbish the original
Thanks for the Link.
Old 04-29-2021, 08:21 AM
ironman's Avatar
Originally Posted by Getter-Done View Post
Thank You so Much.
Not bad mouthing the product but I can tell you this from experience:
# 1. It stinks to high heaven. Get it on your hands or clothing and you still smell it days later.
#2. Keep it stored in the tin can that it comes in and one day you will begin to smell it because it has eaten through the can and has run all over the shelf you had it stored on.
Old 05-01-2021, 06:03 PM
I pulled that 1864 in the sunlight today.
I got a Magnify glass and #2 pencil with eraser.
Put some pencil marks on it and erased it.
I am not 100% sure on serial #
The Model # CH18S and Spec# is 62509.
I found a kit on e bay for $8
Found a new carb for $319.oo.
Are there any Vendor's on the Forum?
Old 05-01-2021, 10:17 PM
Rodster Rodster is offline
Congrats on your purchase. Post some pics.
My 1864 143-684-100 seems to be just a little older than yours but has the same model and spec on the Kohler.
Hard to beat that price for a plug and play unit and confirmation it worked great right out of the box. Cheap enough to have a spare on the shelf!
