1512 Maintenance Questions
I feel silly asking these two questions, but I've not found the info elsewhere yet...
I have a 1512 diesel despite being a Wheel Horse nut. I bought it to resell, but ended up falling in love with the stupid thing and now I think it's earned a permanent spot in the barn. It's probably going to follow me to work this winter so I can plow my workplace's lot on those rare St. Louis snowfalls...and I won't end up smelling of small engine exhaust. Anyway, it is really in need of some preventative maintenance and I can't find the following items in my manuals: 1. What oil filter (Kubota, CC, Fram, Wix, Whatever) does this thing take? The one that the PO used is a Mann filter with an illegible number and I don't know what to cross it to. (Seriously, where does one even find a Mann filter in the US?) As far as I can tell, it ain't in the Owner's manual either. 2. How do you change the hydro fluid in this? I've heard the fluid is pricet, but I don't care what it costs since it needs to be done. The OM has no procedure and I read elsewhere that these typically only get a filter (um, I don't have a number for that either...) and a topoff. I have 40+ Wheel Horses spanning 60 years of production and this one Cub Cadet, but I can fully see hunting down a few more of this style. They seem to drive really nice, the diesel is smooth and quiet, and they seem to be built like brick outhouses. I'm not sure it actually uses any fuel. Implement changeover is a bit cumbersome, but if a 782D, 882, 1572, or 1772 presents itself I can honestly see showing a couple of 'Horses the door... Thanks, Steve |
Oil filters for Kubota D600:
Kubota 70000-74034, 70000-15241 FleetGuard LF3403, LF3462 Napa Gold FIL1334 WIX 51334 AC Delco PF1127 Purolator L14459 Baldwin B179 I would recommend Shell Rotella T 15W-40 for oil if you aren't already using that. I would also recommend using Power Service (or similar) diesel fuel additive if you are using the the new diesel formulation, as the new stuff doesn't have very much sulfur in it, and the sulfur lubricates the injector pump. It still would be a good idea for winter use as it has some anti-gelling stuff in it. There's a drain plug on the trans by the suction line. Drain it, remove the rear cover, clean all the crap out, put the cover back on with a new gasket, and refill with 7 quarts of IH Hytran (can be obtained from any CaseIH or Case heavy equipment dealer...cheaper in bulk) or the CC hydrostatic transmission fluid for the older machines. It's cheaper through CIH or Case. Use only a Cub Cadet (723-3014) or Fleetguard hydraulic filter. |
Matt, what about a Wix 51410 for the hydro?
If it's a hydraulic filter, that's probably fine. I basically meant to stay away from oil filters and Fram filters.
Man! Matt's head must hurt at the end of each day....filled with useful Cub stuff! :biggrin2.gif:
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. Now everyone wants a Cub! Beware of the Wife |
Thanks for the info! MUCH appreciated.
I know Hytran is used in the older machines, but when or on what models did Cub switch to the Semi-synthetic fluid?
I believe the 2000 and 3000 series use the newer fluid.
Matt,
If you don't mind the price, can the semi-syn fluid be used in the older machines? |
No. It is not compatible. Use the older fluid.
