Old 03-21-2009, 09:46 AM
dannsher dannsher is offline
Unhappy New Owner of 169
Need some help folks. I am the proud new owner of a Cub Cadet 169, riddled with problems that I am more than willing to fix, in order to use what I consider one of the best machines ever built! Here is a short list of my bigger probs that I need help with.
1) Need an operator/repair manual.
2) Need to know what type & size of pin goes in the shaft that connects to back of motor going to transmission? It is missing?
3) Where to find add-on implements both front and rear
4) Weights and counter weights, where they go, and where to find?
Any help would be greatly appreciatted! I currently have a 28 hp John Deere, that I quickly donated to the wife when I got this machine. I have waited a LONG time to find this machine and am truly excited about getting it going!! I had a much smaller one a few years ago, but had to let it go due to circumstances out of my control. But now have this one and am looking forward to full use. Because as my grandsons call it this is our tractor - the REAL machine !!
Old 03-21-2009, 10:04 AM
Philip LoPresto's Avatar
Philip LoPresto Philip LoPresto is offline
Default 169
I would think that, the best place to start, would be here on OCC, a wealth of info, good luck Phillip
Old 03-21-2009, 10:27 AM
MBounds's Avatar
MBounds MBounds is offline
Dannsher:
1) You dont need to go anywhere else! What technical info isn't on already this site is readily available from knowledgeable members! Just ask...
2) The Operators, Service and Parts Manuals for the Model 169 are available from www.binderbooks.com. You will also want to get a Kohler K-Series Service Manual for the engine.
3) That missing pin is a IH-19837-R1 Dowel pin (1/4" x 1 1/2") available from any Cub Cadet Dealer.
4) Add on implements?? Advertise in the Wanted Section below....You should also order the IH CPE-2 Parts Manual for Cub Cadet Equipment from Binder Books also...Very helful!
5) Wheel weights and a front counter-weight bracket with weights were options when new. Wheel weights are often available for sale...again post in the wanted section. The front weight brackets are often fabricated and configured for the type weights to be used....Again, ask for a pic of
one!
Myron B
Old 03-21-2009, 10:47 AM
Inactive Member
dannsher:
First, Welcome to our Forum....
An Operator's Manual is available from our Technical Library Section. Look for Manual - Operators - 1x8/9.
Myron answered the rest.
Old 03-21-2009, 11:10 AM
Welcome to OCC dannsher! Glad to have you here. The 169 is also a rare Cub Cadet, only 4,005 were built. Good luck, on your 169.
Old 03-22-2009, 11:27 AM
Thanx much for the warm welcome and the info, has me rollin already !! Again THANX !!!
