Closed Thread
Old 05-09-2011, 11:55 AM
eplummer eplummer is offline
Default craftsman lawnmower
I need some trouble shooting help. The safety cable ,that won't allow you to start the mower unless the bar it is attached to is held against the handle, snapped. Is there a way to get around this safety feature? I can't seem to slide/move the linkage that the cable moved at all. Any help is appreciated. It may become a curb ornament if it is to much trouble.
Thanks
Eric
Old 05-09-2011, 01:05 PM
Dalefan Dalefan is offline
I'm in exactly the same boat with my TroyBilt push mower. I was using it a few weeks ago and the cable stuck in the retracted (on) position. I pushed on the lever on the engine to try and shut down and the cable snapped in the casing.
Old 05-09-2011, 02:40 PM
I hate restarting mowers just cause I have to let go of the handle to move a garbege can or whatever, so to me it is fine. Just don't tell OSHA.
Old 05-09-2011, 04:37 PM
All that bar does is keep the ignition circuit from grounding out. when you release the lever it grounds and kills the spark. I always just put a two position switch on the mower. Flip the switch on to start the mower, and flip it back to kill it.
Old 05-09-2011, 04:42 PM
CC1450's Avatar
CC1450 CC1450 is offline
Be sure to keep your feet well away from the deck though!
-Mark
1978 1450
1976 1450
Old 05-09-2011, 04:47 PM
I would replace the safety switch. It's cheaper and less painful then a trip to the ER. It's there for a reason.
Old 05-10-2011, 07:43 AM
How to Removed.
***THIS IS WHAT I DO...I DO NOT ADVOCATE ANYONE BYPASSING ANY SAFETY FEATURE AT ANYTIME. ANYONE WHO EMPLOYS THE TECHNIQUE DESCRIBED ABOVE DOES SO AT THEIR OWN RISK***
Old 05-10-2011, 11:30 AM
Locking this thread. We are not going to be a place were we are going to teach each other how to disable safety features. It's cheaper and less painful to use all safety devices.
Closed Thread
