Old 04-28-2016, 06:55 PM
JohnHill88 JohnHill88 is offline
Default Super steer axle questions
Hey guys, I have an 1811 and I'm thinking of putting a "super steer" front axle from a 1641 on it. Are there any disadvantages to this? I plan to run a QA42 blower in the winter. Will the super steer axle cause any tire clearance issues with the blower?
Old 04-28-2016, 07:56 PM
the super steer axle will make the tractor sit a little higher in the front, no sure how much or if it would be enough to keep the blower from going down the whole way.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-28-2016, 08:11 PM
I think the question should be, are there any advantages.....
Old 04-28-2016, 08:32 PM
The super steer tractors steer easier than the regular front axle and also turn much sharper. I think it's a good modification if you can get a front axle for a right price. Especially if you can get the mule drive with the larger pulleys.
Old 04-28-2016, 08:40 PM
RLause's Avatar
RLause RLause is offline
I just did this on my 782, raised the front end 2.5". I think it makes the tractor look more aggressive. I have power steering so I don't know if it turns easier, but it does turn sharper, much nicer for mowing.
Richard
Old 04-28-2016, 09:11 PM
SS5150's Avatar
SS5150 SS5150 is offline
Thought I read somewhere that it puts the front tires too close to the QA42 gearbox, and the taller spindle throws off how the thrower sits on the ground (tilted rearward toward the tractor).
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 04-29-2016, 04:31 PM
gdheck's Avatar
gdheck gdheck is offline
It didn't change how my 1450 sits. It did make it turn shorter and harder. I never changed anything but the axle and made a new draglink and it DID make it harder to turn. In fact, I have been thinking about changing it back to the regular axle now that I don't use it as much as I used to.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
