starter problem
My snow blower has one of those wall plug in starters and I have to push the start button many times before it will kick in, it just free spins. When I take it off the drive flyes out all the way just fine. It worked fine till the warrenty ran out. Any Ideas ?
I'd try a little WD-40 on the bendix.
I don't know your model or type thrower you are working on, but on some of them they have a plastic pinion gear with a steel washer inside that if it gets wet or
is oiled it will slip.BTDT Sorry, I'm exhausted, and my ESP just isn't working well. |
y Yep thats just what it is plastic gear. I just don't get why it works fine till you bolt it in ?
Put 1 drop of garage door lube or dry slide on the helix on the shaft.
less is better here. Is it slipping when it engages or just don't engage? |
