Old 01-18-2021, 09:06 PM
ocracokenc ocracokenc is offline
Default XT2 headlights
Hello guys
I know I did the on my LTX-1040 but I can’t remember how I did it and I sold it. I now have a 2020 XT2 GX50 and I want to add a rocker switch on the dash to turn the head lights off when I don’t need them, I just don’t like them on during the day. I ordered a waterproof toggle switch with 12” of lead wire coming from the 2 leads. Thanks for the help......Scott
Old 01-19-2021, 10:02 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Wiring a toggle switch for headlights is pretty simple actually. All you need is a wire from the positive battery terminal to the switch, then a wire from the switch to the headlights. You'll want to disconnect the stock harness wires that deliver power to the lights, but leave the ground wires if you can. If not you'll need extra wires that run from where the ground wires were, to somewhere on the frame of the tractor (remove paint from that spot to ensure proper ground).
That should be all you need unless it's some sort of fancy high/low beam setup, in that case you'll need someone else to explain it because I don't have a clue about that
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 01-20-2021, 05:28 PM
Thanks for the advice. Since the lights have power all the time I should be able to just use the positive wire going to the lights
Old 01-20-2021, 08:00 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Yes! 10 Characters
Plow blade
#2 Cart
QA36 snowthower
Old 01-29-2021, 09:03 PM
Well guys it took me about 10 minutes and I can now just turn the lights on when I need them. I spent the most time deciding the location of the switch but it looks factory almost and works great. Thanks for the help. I am really liking the XT2 GX50
