Old 12-15-2017, 10:16 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Removing fluid ballast
I'm getting a set of mounted Ags and the tires are fluid ballast filled.
How does one get the stuff OUT...? Is there any way to do this other than breaking the tire down or should I do that anyway in order to clean / dry the inside?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-15-2017, 10:36 AM
Unless they are large farm tires, you can handle them easily, so no need to remove ballast for transport.
Now if you are talking about demounting the tires off the rims for some reason, you can take the valve core out with it @ the 6 O'clock position and let gravity, and the air pressure push the ballast out into a container of appropriate size.
Old 12-15-2017, 02:16 PM
jbrewer's Avatar
Hi George, yes, I can wrestle them around, but I just don't want them filled (there's no need).
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 12-15-2017, 02:47 PM
twoton twoton is offline
Tubes?
Old 12-15-2017, 03:02 PM
Talking
You are getting a set of ag's already mounted on rims and they are already filled w/fluid, correct?
May I ask why you do not want the extra weight in a set of ag tires??
If you are going to do any type of ground engaging activity such as plowing, cultivating, grading or even mowing on embankments you may want to reconsider as you will probably need the extra weight for traction. That is, of course, unless you are building a "trailer queen" for shows.
Old 12-15-2017, 04:21 PM
jbrewer's Avatar
OK, ok, I'll give it a try as is.... I will use it for mowing/hauling on an irregular lawn, so I'll give 'em a go.
Tubes? Who knows? :-) I'll post pix when I get em (monday?)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 12-15-2017, 06:31 PM
john hall's Avatar
I'm running loaded ags on an 1811. This is the first year there has ever been a lawnmower with ags, much less loaded ones here on the farm. The places we can go with that machine are amazing. It doesn't ride quite as smooth at "road/travel" speed, but I can live with that.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-15-2017, 08:01 PM
dodge trucker dodge trucker is offline
I was gonna ask the opposite, who fills them these days? I have 2 sets i'd like to have filled.
Old 12-15-2017, 08:08 PM
DieselDoctor's Avatar
There have been several threads on this forum about filling tires with liquid ballast. Search around a little and you'll find that some of our members have come up with some pretty slick ways of doing it.
Old 12-16-2017, 01:19 AM
Take em' off, break the bead on one side, and dump in your fluid of choice. Or if you're doing tubes, you'll have to pump it in...
I use windshield washer fluid, in the tire, no tube.
