Old 10-15-2023, 04:01 PM
M Nation M Nation is offline
Default Need help and info on my beast
I picked this baby 10 years ago for use on our property raking and dragging the gravel drive way.
the Serial number is 2050594U684347 and it has the 782 and international sticker on the panel, I can not fine any other tags. It is a twin cylinder Hydro drive. nothing under seat.
the muffler needs replacing all i find is on ebay and it is well used.
I'm sure my neighbors would be grateful for any suggestions on where to purchase one.
Thanks in advance
Mike
Old 10-15-2023, 07:10 PM
Google the part number, several show up.
Old 10-15-2023, 07:33 PM
Obviously you have an early Cub 782 as indicated on the hood.
The later ones were made by MTD not International Harvester.
Watch the auction sites for a GOOD Muffler and that someone did not remove it with a big hammer and beat it up.
They are not cheap but a good one is worth the cost/effort.
A lot of times the end caps rust through at the seam.
A they can be welded up using act/oxy torch with a 000 tip if one is experienced at it.
An arc or mig. welder is too hot and will not produce a desirable weld.
