Old 09-12-2014, 12:07 PM
garnold's Avatar
garnold garnold is offline
Default Is this a simple thing to use on a cub?
Found this link for a 12hp on CL. As many here will know I'm quite new to the engine world so I'm asking if this engine can be easily altered to run the driver plate on a cub? From what I see in one of the pics the fly wheel looks like it has the holes for the bolts to connect a driver plate right? So is this just a simple replacement of a new screen and getting a driver plate or is there a lot more involved here? Thank you
http://newjersey.craigslist.org/grd/4660204372.html
PS:
Forgot to even ask if you think this engine would even work in a cub because of the oil pan and if that might also create a problem with the driver plate (if installed) aligning up with the clutch.
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 09-12-2014, 12:54 PM
Won't work. Wrong crank and oil pan. Flywheel, not even an issue.
Old 09-12-2014, 01:06 PM
garnold's Avatar
That's what I needed to know. Thank you
73 WIP
75 WIP
Old 09-12-2014, 01:18 PM
rwairforce rwairforce is offline
Jonathan, you're great to have around...Thank you for edumacating those of us that need assistance from time to time.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 09-12-2014, 03:10 PM
bocephus1991's Avatar
You could buy it and maybe trade it to someone looking for a wide base block who has a narrow base engine. Just a thought $150 not a bad price I would try to get it for less . My 2 cents.
Brian
