3 point
Alright, I am tired of wondering. I have a 1863 and I would love to have a 3 point. I saw one at Extreme Motorworks, says it works off deck lift and you can use with deck locked up. I don't know how to lock deck up and can someone explain sleeve hitch vs. 3 point, which one is better? Do they do the same thing, same attachments pro/cons? I need help with this one. thanks all
A 3 point is what its name implies the implements attach at 3 points. The sleeve hitch implements attach at one point. I'm not sure about the advantages one has over the other except the 3 point may be able to take more wear and tear. I believe the sleeve hitch implements are easier to come by. If you have a 3 point you can adapt to a sleeve hitch adapter easier then going from a sleeve hitch to a 3 point in case you wanted to borrow someone elses implement. On the smaller tractors such as ours the 3 point is a "cat 0" which uses a 5/8 pin. As you go up in size the pin size increases in diameter as do the size and weight of the implements. Those are some of the basics that I know I'm sure others will add to it.
You could just make your 3pt independent of your deck.
Rescue11 is doing the independent 3pt on his 1864 in my shop.
Yes it works off of the deck lift, to lock the deck in the highest position you would have to raise the mower deck all the way up, then rotate the deck adjustment screw knob on the back of the tractor. It's very time consuming and you need to remember how many turns you made to get your deck back to the previous setting. Honestly, the cat 0 has alot more adjustability. The cat 0 also has a higher lift capacity and travel range than a cc 3pt. I dont think that any of the cat 0 3pts available for the cub cadets are anywhere close to what they should be in both lift capacity and travel. Not to mention you cant use multiple attachments on both the front and back.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
3 point
I just picked up my 1863 about a week and a half ago ($500) because it had a 3-pt on it. Deals like this are not easily found, but are out there. I don't plan to use the 3-pt until spring. I plan to build a grader/leveler to maintain my 1/4 mile gravel driveway plus circle drive and parking area. I do not plan to use a mower on this tractor. I have no experience yet with mine. The 3-pt keeps the implement "square" with the back of the tractor. A sleeve hitch is like a two dimensional ball hitch. It lets the implement move left and right. Both will lift the implement. The Cub Cadet Attachment Guide, that I got with the 1863, says the 3-pt hitch is, "Used for the rotary tiller, moldboard plow, disc haro or cultivator." The 190-389 Cub Cadet 3-pt is a cat "0" hitch. It works off the deck lift. Cub made a Sleeve Hitch Adaptor, part number 190-386, that allows sleeve hitch implements to be attached to a 3-pt hitch. I have a real nice copy of the Cub Cadet Attachment guide if you want me to scan some of the pages and email to you, just send my your email. I hope this helps. PeterJ
1863 48" deck, 3pt 1864 x 2, 54" deck, power bagger, 48” deck 1811 44" deck 1210 44"deck IH trip plow QA42-A, 451 x 2, 551 42" Earthcavator Driveway Drag USAF Shepherd's Chapel |
So here's a nice project that I would like to build (in my spare time, ha, ha!)
http://www.onlycubcadets.net/forum/s...412#post189412 IHCC 3 point. Plenty of lifting capacity, weight and height. No cat 0. |
Scroll to the bottom. His 3pt is independent of the mower deck, it will lift a heavier load with more lift height withou having to make any adjustments. Oh btw, it uses the same hydraulic lever as the deck lift. http://www.onlycubcadets.net/forum/s...=31710&page=12 If your interested shoot me a p.m. we have something in the works that will evolve the 3point to what it really needs to be.
