Old 03-27-2020, 01:00 AM
modcub72's Avatar
modcub72 modcub72 is offline
Default 10 hp to 16 hp
Can a 10 hp Kohler be bored out to a 16 hp?
Old 03-27-2020, 01:36 AM
It depends,,,
Old 03-27-2020, 01:52 AM
modcub72's Avatar
CAD plans, ssshhh.
.......work with me on this, lol
Old 03-27-2020, 02:21 AM
green407's Avatar
green407 green407 is offline
I suspect not, a 10hp has a bore of 3.251" and the 16hp has a bore of 3.750", that's roughly 1/4" of material from the side wall. I'm not sure on the side wall thickness, but I don't think it will leave you with enough.
128 X 2, 129, 149, 1450 x 2
Old 03-27-2020, 02:47 AM
modcub72's Avatar
Kohler's are tough motors, they can take it.
But I already know that I need to change the stroke to 3.25.
It can be easily bored to that.
Old 03-27-2020, 03:09 AM
green407's Avatar
I'm not debating that they're tough little engine, I love working them good and hard.
The stroke is easily changed with a K301 crankshaft.
You might be able to bore it out to 3.375", making it into K301, but going to 3.750" I don't think will leave you with enough cylinder wall thickness. You'll start the thing and blow the jug right off it.
Old 03-27-2020, 04:28 AM
modcub72's Avatar
Green407, bear with me on this. Cadplans is too. Lol, you'll see.
Old 03-27-2020, 11:26 AM
Merk Merk is offline
You got mail
Project Uncle Dick
Cub Cadet 70
Old 03-27-2020, 11:30 AM
cooperino's Avatar
There are other ways to make extra HP.. Not that I would do it... But there are ways
Old 03-27-2020, 02:20 PM
It depends,,,
The reason I said,,, depends,,, is that different castings were used to build different vintage engines,,
The 10HP engines were not all cast the same way, some were cast to allow a larger bore.
SO,, your 10HP block may be able to be bored out to a different size than another 10HP,,
or,, not, as we do not know what 10HP engine you are starting with,,
SO,, my answer is still,,,,
DEPENDS,,,
